GE refrigerator leaking water from bottom
My GE refrigerator is leaking water from the bottom of it. I put hot water into the drain in the freezer section, but it is still leaking. Could the drain tube still be clogged with something other than ice.
It usually takes 3 or 4 days for the water to show up by the bottom of the fridge, but there is always water underneath it.
Ok, I found the leak. The water storage line has a hole in it right were it connects to the water inlet valve. When you access the water dispenser, water shoots out of the water line onto the floor. :slight_smile:
