GE Range JGBS66REK5SS slow clicking with new ignition & wiring harness
Brand: GE Range
Model Number: JGBS66REK5SS
Main Symptom: Slow Clicking (1 / 24sec) when off after replacing ‘switch and wiring harness assembly’ as well as the ignition module.
Problem started with range continuously clicking when burner was off/on. Ohmed out wiring harness at 0ohms. After replacing the ‘switch and wiring harness assembly’ clicking went to once every 5 sec. After also replacing ignition module, the clicking is further reduced, but still happens every 24 seconds. Doesn’t matter if burner valve is on or off.
Do I have a bad part or is there something else I need? How do I fix this?
Is it doing this to all of the igniters and are you actually getting a spark at the igniter when you hear the click?
I believe it was all of them and there was a spark. Its at our rental, renters said after ~12 hours it stopped clicking. We will see if it lasts. Still appreciate any suggestions on next steps should it start again.
