GE PSS26SGRCSS Water Dispenser line freezes
Brand:General Electric
Model Number:PSS26SGRCSS
Main Symptom:Water Dispenser line freezes
Error Code (if any):n/a
Will the WR49X10173 Heater Kit work in my mode? If not, is there a version that will fit?
This model has a built-in heater in the door, based on the wiring diagram for it. The wire connection point for the heater is inside the door and is not accessible. Since this is the case, a dispenser heater would not be compatible with this model. Unfortunately, the only way to replace the heater would be to replace the door. WR78X11742 Door Asm Fz Kit Ss | Genuine Ge OEM In Stock
Here is the wiring diagram if needed !
31-51607 GE PSS26SGRCSS Refrigerator Mini Manual.pdf (415.4 KB)
