Yes — what you’re seeing can be normal on the PT916SM1SS, and there’s an important distinction between what the display shows and which element is actually energized.
Convection fan during regular Bake
On regular Bake, the convection fan is not necessarily intended to run continuously. GE can use the fan during portions of preheat to improve heat distribution and shorten preheat, then shut it off once preheat is complete.
If you select an actual Convection Bake mode, that’s different—the fan should operate according to that mode’s cycling strategy.
So the fan stopping after regular Bake reaches preheat isn’t by itself evidence of a fan problem.
The illuminated “BROIL” is the interesting part
I would not assume that illuminated BROIL means the broil element is receiving 240 VAC.
The display can indicate what the control is commanding/using as part of the cooking algorithm without giving you a literal element-power indicator. Your observation is more valuable:
- During initial preheat: Bake + Broil energized
- Preheat completed: both shut off
- Temperature dropped: Bake energized
- BROIL indication illuminated, but broil element apparently didn’t heat
That could be completely normal cycling.
Your indicator-light idea would answer this beautifully
I like the diagnostic concept, but don’t connect ordinary 120-V indicator lamps to the element circuits. Each element is a 240-V load, and depending on the control arrangement, one side may remain live even when the element isn’t heating.
If you do this as a temporary diagnostic setup, use appropriately rated 240-V AC indicators connected across the two terminals of each element:
Bake indicator: across BAKE L1 ↔ BAKE L2
Broil indicator: across BROIL L1 ↔ BROIL L2
Then:
Light ON = approximately 240 VAC across element = element heating
Light OFF = no 240 VAC across element = element not heating
That would let you sit in front of the oven and record exactly what the board is doing without repeatedly probing a live 240-V circuit.
Live Power Warning: This involves exposed 240-V circuitry. Any permanent indicators would need proper insulation, enclosure, wire temperature rating, strain relief, and appropriate voltage rating. For diagnosis, I’d actually favor your multimeter over modifying the oven.
For the test you’re doing right now, keep recording actual temperature + Bake element state + Broil element state. Three or four complete cycles after the oven has stabilized at 350°F will tell us much more than the preheat behavior.
And that BROIL display being illuminated while the physical broil element isn’t energized would not, by itself, convince me there’s a failure.
