GE Profile Performance Ice Maker Not working
[quote=bmurph8;290259]I have a GE Proflie Performance that I just replaced the Defrosters on. when I replaced the Defrosters, I damaged a piece of plastic behind the Ice Maker. I removed the Ice Maker and fixed the plastic, but now the Ice Maker isnt making any Ice. The Auger spins when the button is depressed, and water is coming out of the door when fresh water is selected. The fill tube is not iced over from what I can see.
I think I need to test the selenoid but how do I go about doing this. The ice was working just fine before I monkeyed with it. Any help?[/quote]
What piece of plastic behind the ice maker got damaged ?
Was the ice maker working properly before the defrost heater repair ?
Have you checked the wiring behind the wall, maybe a loose connection or wire in the harness, from the previous repair ?
Did you check the ice maker assembly for damage, before you reinstalled it ?
Do you have a multi meter to check resistance and voltage at the water valve solenoid ?
We can help you from there,
:slight_smile: :slight_smile: :slight_smile:
