The electric element is not working. Purchased new part and the inner element does not work. If I switch the blue and white wire the inner works and the outer will not. I think I may have shorter something. The blue wire was not connected properly before I purchased the new part and it arched .
Is there a fuse that may have blown? Could I have shorted one of the relays.
I bought an inlet safety thermistor and that shows resistance but I though it was to read O Ohms for continuity. How do test for resistance and continuity?
Continuity test is something you perform on a device that should normally read zero ohms which does not include thermistor testing. The thermistors are resistors that vary in value depending on the temperature of the ambient air around them. At an ambient temperature of 69 degrees F, the thermistor should read 118 to 122 kohms. That’s thousands of ohms. You must set your meter to a scale that will read that value.
