GE Profile Dishwasher - pump outlet pipe hunt (WG04F08019)
This part is showing as No Longer Available everywhere I’ve checked so far. A repair tech found a leak at the hose connection between the sump and wash motor and needs this part to complete the repair. If anyone knows of a superseding/replacement part number, an alternate supplier who still has stock, or a compatible part from a related model, I’d really appreciate the help. Thanks!
Brand: GE
Model Number: Profile PDT660SSF1SS
Main Symptom: pump outlet pipe needs replacing
Hi Kowalski, if the pipe is cracked rather than completely broken, appliance technicians can often bypass the specialized molded plastic section. You can cut away the damaged section and bridge the gap with a flexible, high-temperature rubber coupling or automotive heater hose, secured tightly with steel hose clamps.
Alternatively, you can replace the entire sump assembly. The part number is WG04F08012, and you may also be able to find it on eBay.
This is great, thank you kindly Jose!
Hi you’re welcome. hope it works out for you.
