GE PDT845SMJ2ES resets after a minute of running. I just replaced the control board
My dishwasher wouldn’t power on. I replaced the control board and it turns on now and will start, but shuts off after 1 minute each time. I am trying to figure out what part needs to be replaced?
Brand:GE
**Model Number:**PDT845SMJ2ES
Main Symptom:shuts down 1:06 seconds after start
What happens & when: After initially starting the machine resets just after a minute.
The first thing that you would want to do is to check and make sure that the wire connections at the junction box are good. If the wiring is good, then check the door switch to ensure that it is good.
I have replaced the control board which fixed my first issue, no power. The machine would start a cycle and stop almost exactly 1:10 seconds. It sounds like the water shuts off and it is about to start a different phase then it just beeps off and acts like it was never on. I replaced the fill switch and the turbulent sensor (recommended in my AI troubleshooting) and still is having the same issue. Would the Machine start if the latch switch wasn’t working? Since it always stops at the same point I feel like there is a sensor failing. I can order and replace the latch switch if you can confirm that the machine will start the cycle with it sensing the door open. I just don’t see how that is a factor as I have to close it to start the cycle.
You will definitely want to make sure that the door switch is good. It can be tested for continuity.
