GE PDT715 Dishwasher starts then stops, code 371 - fills in service mode but not in operation
Brand:GE
Model Number: PDT715SMN2ES
Main Symptom: Starts then stops after a couple minutes
What happens & when: Starts, doesn’t fill, makes some strange noises, then shuts off, no lights or codes (until going into Consumer Error Mode).
Error Code (if any): 371
Parts or tests already tried: Cleaned pressure switch, tested fill, drain, and circulation in service mode
Tried power reset, cleaned everything in the sump and cleaned the pressure switch. Fill, drain, and circulation all work properly in service mode. But it’s not filling when trying to run a normal cycle. Just makes some odd noises for a while, then the “Washing” disappears, makes more odd noises, then just shuts off (all lights go off).
Thanks.
Chris
Nevermind! I didn’t recall the little hole that needs to be unplugged when cleaning the pressure switch. All set now.
That part is cheap.Maybe replace it next time! WD21X25468 Pressure Sensor Assembly | Genuine Ge OEM In Stock
We are glad to hear it was a simple fix, thank you for letting us know what did the trick.
