Brand: GE
Model Number: JBS03 V5WH
Main Symptom: Preheat not working
What happens & when: If i set the temp to 400 the top element turns red and the bottom element get hot enough you can not touch. I replaced the thermostat because it would heat up and not turn off the element , and kept heating up burning what dish that is in the oven.
Parts or tests already tried: Replaced the thermostat
