My daughters GE Nautilus DW wasn’t pumping all the water completely out, left some in the bottom. So I figured just needed to clean the screen as I read online. But on further examination, It wasn’t blasting the water inside like it should, didn’t push water to the top and didn’t drain well. The motor runs fine, the solenoid switches as it should, checked the check valve Part #564 and it looks in good shape, put a new impellar kit in it and still the same result. What else could it be preventing it from washing as it should and pumping out??? Thanks.
I’m having the same problem with my GE Nautilus
