GE Monogram ZISS420DMSS Door Spring Problem
[FONT=Arial][SIZE=3][COLOR=Black]My GE S/S Ref/Frz has a problem with the spring mechanism[/COLOR][/SIZE][/FONT] [SIZE=3]that pulls the door closed. I need help in how I should access the area below the unit so I can see what parts are needed and so that I can make the repair. Does the unit need to be pulled from the wall?
There is an arm below the hinge that is still connected to the door but that is loose. Presumably this connects to the spring assembly… but I cannot see into the area. Any help would be greatly appreciated.
David
[/SIZE]
:mad: We have GE Monogram ZISS 420DMC. The door spring broke off. Can anyone tell me how to replace this spring which goes at the bottom of the door? The old spring is not visible to copy the replacement of this new one.
