Brand: GE
Model Number: ZIS420NMB
Main Symptom: freezer cold, fridge below freezing
**What happens & when:
Started with the freezer climbing to 13°F and the fresh food section at 38°F. Noticed an intermittent knocking — roughly 5–7 knocks at random intervals, almost like someone rapping on a door. There is also a faint high pitched sound inside the refrig. - Power reset stopped the knocking but freezer stayed warm & sound remained. Cleaned the condenser coils, then had a service call — tech added refrigerant.
Post-recharge: freezer is now at 2°F, but the fresh food section dropped to 31°F and the climate control drawer is sitting at 20°F. Cucumbers are frozen solid.
Called the service company back — their assessment over the phone is that the lower air damper handler assembly is the culprit.
Looking at the parts diagram I see two candidates:
WR31X10021
WR60X10063
Given the symptoms - which one is the correct assembly for this model? And is there anything else that should be ruled out before replacing it — thermistor, control board, etc.? Control board was replaced 6 months ago.
