Brand: GE
Model Number:PEM31SF4SS
Main Symptom: Buzzing sound
What happens & when: The door is opened it stops, then when closed it buzz again, keeps time ok. All though it seems to over heat the food.
Error Code (if any): No error codes
Parts or tests already tried: None
My suspicion would be an issue with the internal fan eithrer it has debris in it or there is damage to the blades ( WB06X10860 Microwave Cooling Fan | Genuine Ge OEM In Stock ) or motor ( WB26X21315 Motor Fan | Genuine Ge OEM In Stock ) . To access the fan and motor you will need to
For the GE Profile PEM31SF4SS, the cooling fan motor is located behind the outer cabinet near the control panel area. Access requires removing the microwave from its installation and taking off the metal cover. The OEM cooling fan motor is WB26X21315.
Access Procedure
Microwaves contain a high-voltage capacitor that can hold a dangerous charge even when unplugged. Use caution.
Unplug the microwave.
If built in or under-cabinet mounted, remove the trim kit and mounting hardware, then slide the microwave out.
Remove the screws securing the outer cabinet cover (rear and side screws).
Slide the cover back and lift it off.
The cooling fan assembly is behind the control panel on the right side of the chassis.
Disconnect the fan motor wires.
Remove the screws holding the fan bracket/motor assembly.
Transfer the fan blade to the new motor if required and reinstall.
Before Replacing the Motor
Check for:
