GE Microwave JVM2070SK02 blows fuse after pressing start
Brand:GE
**Model Number:**JVM2070SK02
Main Symptom: No power. Blows fuse
What happens & when: When I press start, microwave immediately shuts off and the 1st fuse is blown. When I replace the fuse, same thing after I press start.
Parts or tests already tried: Replaced fuse
Test the door switches for continuity. They would be they would be the most likely cause for this issue.
Here is the tech sheet.
31-40045 GE JVM2070SK02 Microwave Mini Manual.pdf (543.5 KB)
Good day. I checked the switches (2) SZM-V16-FD-63 and SZM-V16-FD-62(Monitor switch) and they all checked ok for continuity.
With the door switches check ok then this will most likely be caused by a faulty control board.
