GE Microwave JE89 002 stopped working last night. The buttons and light doesn't work at all. Outlet is working fine. Are there fuses to check? If so, where are they?
Brand: GE
Model Number: JE89 002
Main Symptom: not working at all
What happens & when: worked fine yesterday, then last night it was dead
Parts or tests already tried: outlet is working fine
Check that outlet plug with a lamp or radio to be safe.
Things inside the microwave that could make it go dead…
Fuse
Fuse Holder - NLA
Thermostat - NLA
NLA is No Longer Available.
Fuse can be tested with an ohm meter or simply replace the fuse as your test and yes the cabinet must come off to check the fuse.
Microwaves can still shock you when unplugged.
How to discharge a microwave capacitor
jeff sr
