GE jsp34bdw3bb, slide in range, replacement part wb27x27460 wiring harness doesn't match
Brand:GE
Model Number:jsp34bdw3bb
Main Symptom: wiring harness doesn’t match original part.
What happens & when: 5 pin harness doesn’t match pins on replacement part, off set by one pin.
From the pictures it looks like your model is JSP34BW3BB which uses control board WB27X23660. That control board has been discontinued by the manufacturer and is no longer available for purchase. The manufacturer does not list a compatible substitute or replacement part. This control board came with a pigtail for just what you’re seeing, but they don’t make it anymore.
WB27X27460 is the correct control board for JSP34BD3BB.
https://www.appliancepartspros.com/ge-control-ovn-erc3b-wb27x23660-ap5955116.html
