GE JHP63V0K1 - Oven -
Brand: GE
Model Number: JHP63V0K1
Main Symptom: Heating Element Broken
What happens & when: Always
I need the part number for the lower heating element of the upper oven please
Here is the part number # for the upper oven bake element ( GE WB44X5082 Range Oven Bake Element | Genuine OEM Part )
Thank you, but the picture of that part does not match the part I need. I don’t think WB44X5082 is the right part because it looks too big and is not the same shape as the existing part.The upper oven heating element is smaller and a different shape. The two electrodes connect through the right side of the top oven. Is the part number you posted for the TOP oven, not the bottom number? I must be missing something.
Yeah I’m sorry I didn’t think it was the right one but a couple of people in the office said it was. Try this ( GE WB44X195 Range Electric Oven Bake Element | Genuine OEM Part )
Thank you. This looks more like the right part except in the picture the whole thing would need to be rotated so that the straight part (width) was going across the back instead of the front.
I don’t know if it matters how the two electrodes connect through the right side wall of the oven, if there would be a polarity issue. I can’t see where/how to upload a picture.
There would be no polarity issue with which way you connect it
Thank you very much for your help
