GE JGB700EEJ2ES gas broiler igniter glows but never lights. Oven works fine
Brand:GE
**Model Number:**JGB700EEJ2ES
Main Symptom:Broiler won’t light
What happens & when:Broiler igniter glows, but never lights
Error Code (if any):N/A
Parts or tests already tried:None
More than likely, the igniter is too weak and is not drawing enough amps to open the safety valve. If a meter is available, an easy check is to access the safety valve, set the meter to Volts AC, and test from the broil igniter wire connecting to the safety valve to the wire on the terminal next to it. Does the voltage reading show between 3.2 to 3.6 Volts AC or is there a different reading? If the voltage is less than 3.2 to 3.6 Volts AC, the igniter has failed. WB13X40207 Gas Range Oven Igniter | Genuine Ge OEM In Stock
