GE Ice Maker Auger Not Turning despite installing new motor
Brand: GE
Model Number: TFX25PPBAWW
Main Symptom: When pressing ice dispenser lever on the outside of the freezer door, hum sounds, ice chute opens, but auger does not turn.
What happens & when: Was working perfectly fine, then one day the auger stopped turning and ice was not dispensed. Pressing the lever would cause the exact same hum sound, but no ice. I removed the ice tray and ensured no jams, then I recorded a video with the freezer door closed and when pressing the button you can see the solenoid pick up to open the ice chute, and hear the hum, but the auger shaft (with the fork-like attachment) doesn’t turn.
Using your AI, I ordered a replacement motor (P/N: WR60X10262, Order #17433683) and installed the new motor. Nothing changed, the auger shaft still does not turn. See attached video link with the NEW motor installed.
Suggestions on what to check next? Is there a fuse somewhere to the motor? I can’t check the motor voltage because the door has to be shut to actuate the motor. Is there another way to check that voltage is getting to the motor?
Error Code (if any): N/A
Parts or tests already tried: P/N: WR60X10262, Order #17433683
Photos / video link: https://drive.google.com/file/d/1FpGnBLou9hAFFNnfd1myagFICFwu4ip-/view?usp=sharing
When you changed your motor did you reinstall the auger drive hub (GE WR2X4854 Refrigerator Auger Hub | Genuine OEM Part)
and the j nut (GE WR1X1547D Refrigerator J-Nut Kit (12-Pack) | Genuine OEM Part)
Thanks for responding! Yes, I did. Also, although I didn’t show it in the video, I could grab the auger drive hub and turn it and the motor turned very slowly. Can you think of a way I can test if power is getting to the motor? All I could come up with was disconnecting the leads to the motor and taping the connections to my multimeter probes, shutting the freezer door and recording the multimeter reading when I press the switch?
Yes, you’re on the right track! Your idea of checking voltage at the auger motor while pressing the dispenser switch is exactly the test I would recommend. And the fact that you can turn the auger drive hub by hand, even though the motor turns slowly, is helpful information.
For your GE TFX25PPBAWW, here’s how I’d check it.
  1. Unplug the refrigerator and disconnect the two power wires going to the auger motor.
  2. Set your multimeter to AC volts (VAC), using a range above 120 volts.
  3. Connect your meter probes to the two wires in the harness that supply power to the motor, not the motor terminals themselves. Insulated alligator clips would work better than taping the probes.
  4. Make sure the connections are secure, insulated, and cannot touch each other or any metal.
  5. Close the freezer door, or activate the door switch if accessible, and restore power.
  6. Select crushed or cubed ice and press the dispenser paddle while watching your meter.
Here’s what the readings tell us:
  • Approximately 120 VAC: Power is reaching the motor circuit. If the motor won’t turn when connected, I’d suspect a failing auger motor or something mechanically binding.
  • 0 VAC: The motor isn’t receiving power. We’d need to check the dispenser switch, door interlock switch, wiring, and control circuit.
  • Low or fluctuating voltage: This could indicate a poor connection or a problem in the dispenser circuit.
One important detail: Testing with the motor disconnected tells us whether voltage is available, but it doesn’t prove the circuit can deliver enough power to operate the motor. If you measure 120 volts, the next step would be checking voltage with the motor connected and the dispenser activated.
Safety note: This is a live 120-volt test. Only use properly rated insulated clips and leads, make all connections with the refrigerator unplugged, and don’t leave exposed metal connections inside the freezer.
Also, I wouldn’t condemn the motor just because it turns slowly when you rotate the hub by hand. The motor’s gearing can make it difficult to turn manually.
One question: When you press the ice dispenser paddle, do you hear the auger motor humming or attempting to run, or is it completely silent?
That will help us narrow down whether we’re dealing with a motor problem or a power supply issue.
Here is the mini manual for you model:
31-51183 GE TFX25PPBAWW Refrigerator Mini Manual.pdf (404.7 KB)
Thanks Jeffrey and Buck for the info. I’m going to test the leads to the motor today.
As it sits now, pressing the dispense paddle lever on the front of the freezer door causes the ice-chute solenoid to actuate, the ice chute door to open, and a loud hum, which is the usual sound the ice maker has made since I bought it. I believe the hum is coming from the solenoid, not the motor. So I have power confirmed through that branch of the wiring diagram that Buck provided.
I also saw from Buck’s wiring diagram that the power to the solenoid is different than the power to the motor? I thought that was odd. So its possible that power is reaching the solenoid, but power is not reaching the motor. Is there a power failure point that is unique to the motor but not the solenoid? Being that both my original motor (that I thought was bad even though it meggered at 8 ohms) and the new motor I bought from APPros don’t work, but yet both turned freely when I turned the auger by hand, I doubt both of those motors are bad. I’m expecting to not have power at the motor terminals, so I’m thinking ahead of what would be the next thing to check.
Thanks for the help!
Kevin
OK, I have some more troubleshooting data. I disconnected the motor and connected my multimeter to the motor leads.
With the ice dispenser paddle not pressed in, meaning the “normal, at rest” state of the ice dispenser, and the freezer door open with the freezer light on, there was 5.29Vac present at the leads of the motor.
When I shut the freezer door, and the interior freezer light turned off, the voltage jumped to a steady 10.68 Vac at the leads of the motor.
When I next pressed the ice dispenser lever, with the freezer door closed, the voltage jumped to 23.47Vac at the leads of the motor while I maintained the lever pressed.
What do you think these measurement readings point to check next?
Thanks for the help,
Kevin
Thanks for taking those voltage readings. They give us some useful information, and I think we’re getting closer to finding out why the auger motor is running slowly.
For your GE TFX25PPBAWW, the most important reading is the 23.47 VAC when you press the dispenser paddle with the freezer door closed.
Assuming this refrigerator uses the standard 120-volt AC auger motor, that voltage is much too low to operate the motor properly.
Here’s how I interpret your readings:
Test condition
Voltage
What it tells us
Door open, paddle released
5.29 VAC
Likely stray or induced voltage
Door closed, paddle released
10.68 VAC
Also potentially stray voltage
Door closed, paddle pressed
23.47 VAC
Too low if the motor requires 120 VAC
The first two readings aren’t particularly concerning because the motor was disconnected. A digital multimeter can pick up small amounts of voltage through other components even when the circuit isn’t supplying usable power.
The third reading is the one we need to investigate. However, we should verify it under a load before concluding that the dispenser control or wiring is defective.
What I’d check next
1. Confirm which motor wires you’re testing. Some GE auger motors have separate connections for cubed and crushed ice. If yours has three wires, we need to measure from the common wire to the appropriate motor wire, not between the two direction wires.
2. Repeat the voltage test with the motor connected. Unplug the refrigerator, reconnect the motor, and arrange insulated back-probes so you can measure across the correct motor connections. Restore power and briefly activate the dispenser. If the voltage remains around 23 VAC, we know the motor isn’t receiving proper operating voltage.
3. Check the freezer door switch. Since the voltage changed when you closed the door, inspect the switch and its connections. A switch can operate the light normally but still have a problem with a separate dispenser interlock contact.
4. Inspect the dispenser wiring and switches. If the door switch checks out, the next suspects are the dispenser switch contacts, wiring connections, and dispenser power circuit. We can narrow these down using the wiring diagram before replacing anything.
Since you’ve already replaced the auger motor with WR60X10262 and the problem remained, I would concentrate on the electrical supply rather than purchasing another motor.
AppliancePartsPros Forum
+1
One question before the next test
How many wires are connected to your auger motor — two or three, and what colors are they?
That will help me identify the correct connections for the next voltage test. I want to make sure we’re measuring the actual motor supply before we condemn a switch or control.
Safety: These are live-voltage tests. Always unplug the refrigerator before moving probes or disconnecting wires, and keep all connections fully insulated.
There are only two wires connected to my auger motor. The voltage measurements were taking at these two leads disconnected from the motor.
I reperformed the test with the motor connected and got the same result. I’m assuming the correct voltage would be ~120Vac?
Also, what’s the best way to get to the switches you are talking about? Can you tell me how to get to the freezer door switch and the dispenser switch?
Thanks,
Kevin
Thanks for clarifying that. Since your GE TFX25PPBAWW refrigerator has only two wires going to the auger motor, you’re measuring voltage in the correct place.
Yes, you should expect approximately 120 VAC across those two wires when the ice dispenser is activated, provided the door switch and dispenser switch are working correctly.
The earlier readings of 5.29 VAC with the freezer door open and 10.68 VAC with the door closed are much too low to operate the motor. However, those readings were taken without pressing the dispenser paddle, so they don’t necessarily indicate a problem. They could simply be stray voltage.
The important test is what happens when you actually call for ice.
1. Check the voltage while dispensing ice
  1. Leave the two wires connected to the auger motor.
  2. Set your multimeter to AC volts.
  3. Carefully back-probe the two motor connections.
  4. Close the freezer door, or hold its door switch in the closed position.
  5. Select cubed ice and press the dispenser paddle.
You should see approximately 120 VAC while the dispenser is activated.
  • Around 120 VAC: The motor is receiving power. If it turns slowly or won’t turn, suspect the motor or a mechanical obstruction.
  • Low or no voltage: We need to check the dispenser switch, door switch, and wiring.
  • Voltage starts at 120 VAC but drops when the motor tries to run: Look for a poor connection, failing switch, or wiring problem.
Live power warning: These are exposed 120-volt connections. Unplug the refrigerator before attaching or moving probes, and keep your hands away from the connections while power is on.
2. Accessing the freezer door switch
The freezer door switch is located along the front edge of the freezer compartment, where the door presses against it when closed.
  1. Open the freezer door and locate the small spring-loaded switch.
  2. Press and release it several times. It should move freely and click.
  3. Unplug the refrigerator.
  4. If you need to remove the switch, carefully release the retaining tabs with a small flat-blade screwdriver and pull it forward.
  5. Disconnect the wires and check the switch for continuity with your multimeter.
The switch should change between continuity and OL when you press and release the button.
Manualzz
3. Accessing the dispenser switch
The dispenser switch is behind the trim surrounding the ice and water dispenser on the outside of the freezer door.
The service instructions for this older GE dispenser design describe the following procedure:
  1. Unplug the refrigerator.
  2. Carefully remove the plastic crushed/cubed ice selector button.
  3. Wrap a small putty knife with masking tape to protect the door finish.
  4. Gently pry the bottom edge of the dispenser trim outward.
  5. Work around the remaining edges to release the trim.
  6. Remove the two screws securing the electrical bracket cover.
  7. Move the cover aside to access the dispenser switches and wiring.
You can then disconnect the appropriate switch and test whether it opens and closes electrically when the dispenser paddle is pressed.
4. What I’d recommend next
Since you’ve already replaced the auger motor and the ice chute solenoid operates when you press the dispenser, I wouldn’t purchase another part just yet.
First, check the voltage at the connected auger motor while actively dispensing ice. That measurement will tell us much more than the 5–11 volts you saw while the dispenser was idle.
One question: When you press the dispenser paddle, does the motor voltage increase to approximately 120 VAC, or does it remain around 10 VAC?
That will help us decide whether to concentrate on the dispenser switch, freezer door switch, or wiring rather than replacing another motor.
I was able to take the measurements you suggested, and more.
With the motor connected, the freezer door closed, and the ice dispenser paddle pressed, I again got a steady ~25Vac at the motor leads.
I next checked the voltage at the actual terminal connection where the auger motor assembly plugs into the back of the freezer. The voltage between the orange and black terminal points (the connector for the motor leads) was also ~25Vac. The voltage between the orange and purple terminal points (to the door lift solenoid) was ~120Vac. This validates that the door solenoid is functioning and receiving proper voltage, and the motor is not.
I next checked the freezer door switch and the switch checked normally for continuity. The Grey wire had 120Vac in one position, and would toggle with the switch position. The Red wire had 120Vac in the other position, and would toggle with the switch position. So the freezer door switch works as expected.
I next checked the paddle switch and the switch makes contact and delivers 120Vac to control board. When closed, 120Vac was on both the red and grey wires on P2-3 and P2-4 connector.
The freezer door dispenser light works normally with the paddle switch, and the on/off light selector switch also turns the light off or on with paddle operation.
The water dispenser also works normally, when selected to water and the paddle pressed, water is dispensed.
The water / cubed / crushed dispenser switch also appears to work normally as the functions switch between them, albeit it provides ~25Vac to the auger motor circuit instead of ~120Vac.
So what should be the next thing to check? Is there another terminal position I should check for 120Vac?
To recap - the exterior door light, interior freezer light, ice cube maker, door light switch, paddle dispenser switch, water dispenser, freezer door open/closed switch, and the solenoid that opens the ice chute all work. I just continue to get ~25Vac at the motor when I should get ~120Vac. What should I check next?
Thanks,
Kevin Collins
Looks like your losing voltage to P1-4 on this wiring diagram.P1-4 is on the control module in a green line I put on this wiring diagram. So it looks like the BLACK wire that supplies voltage is corrupt somewhere.The purple circle has the P1-4 wires there.Look for voltage between the Black wire and orange and see if there is any there.Also first look at where I put another purple circle at the top of the wiring diagram labeled wires to cabinet. Ok now under the top left hinge on the freezer door take the plastic cover off and there should be a molex connector with all the wires there.Make sure there is no bad connection there.
31-51183 GE TFX25PPBAWW Refrigerator Mini Manual.pdf (680.1 KB)
Buck - This is great, thanks. Super appreciate the color-coded version of the schematic. Will definitely deep-dive those areas next. What am I looking for here… A chaffed wire? Could the control module itself be bad? Is the fact that the auger motor just suddenly stopped working / voltage dropped suddenly from 110V to 25V one day with no warning (while everything else still works!) at all informative?
My (limited) experience here is that usually when its a short, it takes the voltage down everywhere. I was really surprised that the orange-purple wires had 120V on the connector (as well as everywhere else I could check for 120V on the schematic) when the orange-black auger motor wires had 25V. Is it possible that “half” of that break-before-make three-way switch is bad, such that it connects the power to the purple wire but not the black wire?
Thanks for any help, I’ll dig back in tomorrow.
