Brand: GE Hotpoint Model Number:Htw265asw0ww Main Symptom: motor won’t shut off What happens & when: I unplug it, wait, plug it back in and the motor still runs, basket doesn’t turn. First time I heard it, it went on by itself and stationary tub had a few inches of water in it. After I unplugged it and plugged it back in, motor still ran, basket still not moving. Kept it unplugged.
Error Code (if any): No coe
Parts or tests already tried: None
There was no cycle. I came in from outside and I heard the washer motor. I knew I didn’t put anything in the washer so why it became possessed is beyond me.
Since the motor starts running immediately whenever power is restored, even with the washer idle, this is almost always a control problem or a motor drive problem rather than a mechanical transmission issue.
My son in law found the skematics in the washer, but he’s not understanding the fault chart. Doesn’t know how to access the consumer fault mode, please advise.
Entry into Consumer Fault Mode ������������������������������������������������������ • Cycle knob should be in 12 o’clock position, then • Press and hold Start button for 10 seconds • After holding the Start button for 10 seconds, all LEDs will turn on, signifying the user may release the button and the machine will boot into CFM Behaviors
I have attached a copy of the tech sheet is this what you found?
yes, that’s the paper. Son in law may have fixed it. Not sure what he did, but he was able to get the board to behave. I just put in a load so will have to wait to see if it completes normally. Will advise. In the meantime, thank you for your help and direction.
