GE GTWN5650F1WS washer new coupler does not fit and screw does not go in all the way
Brand:
Model Number:
Main Symptom: new part does not fit
For model GTWN5650F1WS with agitator coupler WH43X10032, I would check the following:
  • Is there any corrosion, rust, or debris buildup on the transmission shaft splines? The new coupler must seat fully on clean splines. Cleaning the shaft splines before installation is a recommended step.
  • Did the old retaining screw come out completely, including any broken portion that may have remained in the shaft?
  • Was the retaining screw replaced with a new screw during the repair? The coupler should be secured properly to prevent slipping. Replacement screws are commonly used with this repair.
  • When the old coupler was removed, were any of the shaft splines worn, rounded, or damaged? Damaged splines can prevent the new coupler from engaging correctly.
Please let me know:
  1. Whether the agitator is slipping, not agitating, or making noise.
  2. If you have a photo of the transmission shaft and coupler installed.
That will help determine whether the issue is with the coupler installation or the transmission shaft itself.
