Brand: GE
Model Number: GSD2100V65WW
Main Symptom: won’t drain
What happens & when: the solenoid engages, the motor runs, but it doesn’t drain. When rinse is active, you can hear the water moving about inside, so the pump is working.
Parts or tests already tried: Drain hose is clear. Pump has been removed, nothing is clogging the drain hose.
Photos / video link: video of solenoid (hyperlapse) Microsoft OneDrive
