Brand: GE
Model Number: GNE29GMHBES
Main Symptom: Fridge not reaching the set temperature
Parts or tests already tried: I have replaced the Evap fan, Evap Cover, and Evap Air Tower. I tested the fridge temp sensor, and it reads the correct ohms for ice water temperature. The defrost sensor is reading ohms, so it doesn’t have a dead short. The display reads an actual temp of 34 degrees, while my digital grill thermometer reads 41 -45. Sometimes it will get down to 37. I have it set at 34 on the control panel. The Freezer is fine and reaching its set temp with no issues, so I think the 3-way valve is fine too. I considered changing the temp sensor and defrost sensor just in case. What else could it be?
When you’re testing the temperature in the fridge, are you placing the thermometer in a glass of water or some other liquid medium sitting in about the overall middle of the fridge section? I ask because that’s what the manufacturer considers the accurate testing procedure, and with the given temps being that close to what is considered in range I don’t want to give you bad information.
I pulled the temp sensor out of the housing, placed it in ice water on the top shelf, and let it sit for a bit. I also put a digital thermometer in it to verify the water’s actual temperature.
Sorry, I meant how are you testing the actual temperature in the fridge section with that thermometer to get that 41º-45º reading?
Yes. The fridge temp sensor is in the top of the case. so I have the grill temp sensor placed on the top shelf to read actual temps. I just put a mercury thermometer in there to make sure I am getting the same reading.
