Brand: GE Model Number: GNE22GGEBFBB Main Symptom: Fridge and Freezer not colling properly. Compressor and fan running properly it seems. Likely cause ??
Error Code (if any): NA
Parts or tests already tried: Compressor and Ran running, cleaned coils
Follow-up . . . . evaporator fan not running. Freezor this AM at -0-, fridge at 55. The coils are NOT evenly frozen top to bottom. Issue the fan motor or larger issue at hand ??
Yesterday when we spoke, the freezor temp increased to 11-12, then we unloaded the freezor and the temp last evening decreased to -8. Is this also an indication that the issue is the fan motor ??
If so, can you please provide the part number such that I can order.
That increase may have been a defrost cycle, the drop to -8 was probably because the unit was trying to cool the fridge and ended up overcooling the freezer because it couldn’t move that cold air to the other section. So still likely to be fan related.
