GE GDWT308V00WW Cycle button was pressed and now remains recessed. Can this be fixed?
Brand:GE
Model Number:GDWT308V00WW
Main Symptom:Cycle button is pushed in
Phot
os / video link:
It might be possible depending on what is causing this. With the power supply turned off, the outer door panel would need to be removed so that the console can be inspected. This will allow the user interface control to be checked to see if a mounting bracket has broken, if the button just got pressed a little too firmly and needs to be reset, or if something else has happened. Let me know what you find. Unfortunately, if the control or the console have been damaged, they are no longer being made from what I see in these links.
User and main control kit- https://www.appliancepartspros.com/ge-control-tactile-asm-wd21x10504-ap5645721.html
Console- WD27X10318 Console Asm Kit Bb | Genuine Ge OEM In Stock
Thanks for the reply William. So remove the outer door panel and inspect the console and user interface. What the user pushes is a little silicon button which pushes the physical switch below? That’s what it looks like to me on the drawing. So either the bracket is broken and that’s why the button remained pushed in or the user was a little to firm when pushing the button and remained pushed in. From the drawing it looks like the buttons/silicon are all one assembly and this is discontinued, same with the mounting bracket. So if the bracket is broken there is no way to fix this. So to inspect these assemblies you only need to remove the outer door panel? And how difficult is that?
You are correct and accessing the console is not necessarily difficult.
okay. Some screws somewhere on the door panel? I’m looking at the drawing now.
This link can be used as a general reference for disassembling the door. https://www.youtube.com/watch?v=5c1m_rlQFsQ
Awesome. I was just on youtube searching. Thanks William. This GE unit is at a rental so I will probably look at it this weekend. Hopefully it’s a simple fix or I will be buying a new dishwasher. Appreciate all the help.
I fixed it William. The small plastic piece that one screw was attached to was broken off on one half of the bracket. But there was more plastic below with a hole in it. So I got a longer screw and that worked to attach the bracket and hold the buttons in place. Thank you for all the help. :slight_smile:
