Brand: GE Model Number: GSS25WGPAWW Main Symptom: The freezer section temperature fluctuates from -20 to 20 degrees F. What happens & when: The freezer will stay cold for about 30 hours then it will heat up to around 20 degrees. After several hours it will start to back down and get below 0. If I reset the fridge by unplugging it for 10 minutes it immediately starts to lower in temperature.
