Brand: GE
Model Number: DWSR483GB0WW
Main Symptom: Correct Wiring
Parts or tests already tried: WE17X10010
Replacing the old motor with WE17X10010. Need the wire positions to the new motor terminal block. The orange terminal block with connections does not have numbers. Looking from blower end, Ground is on the left. Green is easy to match up. I have a yellow wire with a jumper for the door switch. A red wire for the drum switch. Black wire for the thermostat. And a second red wire going back to the control panel. Please advise where the wires connect going from left to right (again green/ground is on the left). Thanks!
