GE Dryer (GTD33EASK0WW) has no continuity between 8 and 16 on thermostat
Brand: GE
Model Number: GTD33EASK0WW
Main Symptom: No heat when drying
What happens & when: We have no heat when drying
Error Code (if any): no continuity
Parts or tests already tried: We found no continuity when testing two locations
Photos / video link: was following this video (https://youtu.be/OOfaqqe2zLE?is=EZM2VLaax8iEf0w1) and when we moved from timer to thermostat, we had no continuity after the first test.
For your GE dryer model GTD33EASK0WW, having no continuity between points 8 and 16 during troubleshooting could indicate an open thermostat, thermal safety device, or another break in the heating circuit. However, we need to identify exactly which two components you’re testing before determining what needs replacing.
Here’s what I recommend checking next:
  1. Unplug the dryer and make sure it is completely disconnected from power.
  2. Test the high-limit thermostat. Remove at least one wire from the thermostat and check continuity across its two main terminals. At room temperature, it should normally read close to 0 ohms.
  3. Test the cycling thermostat. Check across the main switching contacts, not the smaller heater or bias terminals if equipped. These contacts should normally have continuity at room temperature.
  4. Test the heating element. Disconnect its wires and measure resistance across the element terminals. You should typically see approximately 10–20 ohms. Also check each terminal to the metal housing; neither should show continuity.
  5. Check the thermal cutoff. If equipped, it should have continuity at room temperature. An open thermal cutoff will prevent heating.
If all these components test good, the next step would be checking the timer contacts, wiring, and incoming 240-volt supply.
One important question: When you say there’s no continuity between points 8 and 16, are those numbers from the troubleshooting video, or are they terminal numbers on the dryer itself?
Also, does the dryer tumble normally but produce no heat?
Those details will help narrow down the problem without replacing parts unnecessarily.
