GE dryer DBXR463EB0WW wiring for new replacement motor WE17X10010
Brand: GE
Model Number: DBXR463EB0WW
Main Symptom: Need Wiring help for new motor. GE does not have instructions for my specific model dryer, which has no wiring harness.
What happens & when: motor bearing noise
The GE instructions all show a purple wire and Mmy electric dryer (DBXR463EB0WW) does not have a purple wire, although GE says the new motor (WE17X10010) is the replacement motor for it. My wiring is a green ground (no problem there), a brown/yellow (run winding), which I’m pretty sure goes to terminal 4, and the below wires described, which I’m unsure of where to connect to th new motor harness:
1. what terminal number my pink belt /idler pulley switch wire goes,
2. what terminal the double paired red/ red & black wire (supplying the main power) and door switch goes,
3. what terminal the single red wire that goes to the Start switch on the top panel goes,
4. What terminal the red heater coil wire goes, and
5. Terminal for the red thermostat wire.
I REALLY appreciate any help!!
Instruction sheet GE Dryer Motor WE17X10010.pdf (830.1 KB)
