GE Dishwasher
Dishwasher does not pump out. Drain & Drain hose have been verified as clear.
When cycle gets to where it should pump ou, we hear a hum & ticking from control panel. Cannot tell if pump is attempting to activate.
How can I determine if it is the control panel or if it is the pump that is not working?
Disconnect the pump and see if it still hums and clicks at the control. If it does, replace control, if it does not check to see if the pump is locked up or shorted internally..
Ardvaark
[quote=Ardvaark;479795]Disconnect the pump and see if it still hums and clicks at the control. If it does, replace control, if it does not check to see if the pump is locked up or shorted internally..
Ardvaark[/quote]
What are the Appliance Pro part numbers for the control & for the pump?
AP4484688 [B]pump
[/B]AP4484676 control
Ardvaark
