GE PDW9700J00II
There are two prongs on the back of the soap dispenser. There are two connectors that attach to them, one has two white wires, the other has one red wire with a yellow stripe. Does anyone know wich connector goes on wich prong. (One is closer to the front, the other closer to the back.) If not does anyone know where to find a wiring diagram.
Thanks for the help!
Should not make a difference as it runs off of 120 volts AC.
But you could check it in the following
31-9137 GE Profile Dishwasher Service Manual - ApplianceDigest.com
You may have to join the site to download the manual but it is free and this is a very good site for manuals.
Thats a great site. I found a picture of the module and the wiring.
Thanks very much for your help
