GE dishwasher will not fill with water!
I am not a handy-woman by any means, but my GE Quietpower dishwasher is not filling up with water and I have already checked the floating device. I cleaned it and it’s cover and wiggled the actual device in it. Nothing changed. I am having to fill it with water before I start the wash cycle and about half way through it as well. If I don’t the dishes are not cleaned and food is then stuck on everything! Help!
[QUOTE=joyelizabeth;311189]I am not a handy-woman by any means, but my GE Quietpower dishwasher is not filling up with water and I have already checked the floating device. I cleaned it and it’s cover and wiggled the actual device in it. Nothing changed. I am having to fill it with water before I start the wash cycle and about half way through it as well. If I don’t the dishes are not cleaned and food is then stuck on everything! Help![/QUOTE]
When you lift up and down on the float, you should here a clicking noise. Which is the float switch. If you here that it is most likely good. It would most likely be the water valve on the dishwasher. It is where the water line hooks up to the dishwasher. I know this sounds crazy, but be sure the water is turned on to the dishwasher under the sink. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
