GE Dishwasher will not drain
My GE dishwasher works fine except it does not drain water out. No leaks. Is it the control panel / switch or maybe a check valve? Any help would be appreciated. Thanks
Your unit has a drain solenoid attached to the pump, do you know whether it’s activating or not? It will usually make a “clunk” sound when it does. If it’s doing that, you may want to make sure there isn’t an obstruction in the outlet where the drain hose attaches.
You didn’t just install a new garbage disposer did you? Below is a picture of the solenoid.
AP2039738
Thanks Frank, I will check the solenoid. It isn’t making any sound when it is supposed to kick in and start draining.
