GE Dishwasher wash cycle only
The timer appears to be functioning, and the soap despenser opens, but the machine doesn’t fill with water or drain. There is water left in the bottom of the machine from a previous wash cycle and when the machine is turned on, it sounds like a normal wash cycle, but still no filling or draining.
Open the control panel and check the pushbutton switches on the left side. Most likely the problem is there.
  • The part number for the switches kit is AP2617405
Here are the break down diagrams and Replacement parts for GE GSD3220Z02BB | AppliancePartsPros.com
