GE Dishwasher - PDT720SYZ1FS has no power
Brand:GE
Model Number: PDT720SYZ1FS
Main Symptom: no power
Parts or tests already tried: Tested power from the wall.
I’m looking for the correct control board. This is a newer model, and the replacement board I received doesn’t fit. Any help in this search would be greatly appreciated.
Here’s a picture of the board I removed for reference:
Hi cimmel,
According to the model number you provided, this is the correct OEM control board for your appliance:
i’ve also attached a tech sheet that can help you run diagnostics and narrow down the issue before replacing any parts. It can help identify any error codes and guide you through the testing process.
pdt720 31-30670-Mini-Manual-17660.pdf (2.7 MB)
Thank you for your help!!
