Our dishwasher does not drain all the water out, it leaves about an inch of dirty water at the bottom. I have cleaned the drain out of the bottom of the dishwasher, it was full of dried soap. It worked fine for a few loads, then started not draining again.
I’ve checked the air gap for debri, but found nothing. Is there something else to check before a technician is called?
Thanks,
jason
