We just moved into a house and ran the dishwasher. We found out that the some standing water was left at the bottom (about 1’’ deep). GE Model: GSD6860J01SS
Does this unit have the piston and nut assembly which often fails?
We tried using rinse only but it did not work either.
No it does not
It has a separate drain pump (Item 325 i Section 5).
Could be clogged filters, a bad flapper valve (Item 328), a bad /clogged pump or a blocked drain hose.
A common place for the hose to plug is where it attaches to the house plumbing so I would start there. Item get stuck on the fitting and build up causing a partial plug.
Thanks, Denman. I will disconnect the drain hose from the house plumbing and check if it drains ok. Then let you know the results for further advice. Thanks.
