The dishwasher leaks when water is being pumped out of the washer - after the first rinse, then after the wash, then after the final rinse. The rest of the time, while washing, no leaks. total leak amount is about 1 cup per load. What shoudl I replace?
Replacement parts for General Electric GSD1130R45WA Dishwasher | AppliancePartsPros.com
[COLOR=“Blue”]What shoudl I replace?[/COLOR]
Only you can tell as there are a number of items in the drain path.
Remove the kick plate and find the leak.
May be as simple as replacing a clamp.
A small mirror and a flashlight come in handy when trying to track down leaks.
A mirror like the ones mechanics use, which is on a handle is ideal.
Yo could also tape a small mirror to a piece of doweling etc.
