Brand: GE Model Number:GDT655SMJ2ES. Main Symptom: The control panel lights are not on and nothing happens when I push any buttons. What happens & when: Several people on some forums indicated this was due to master control board dying. I ordered and installed WD21X2901C. The control panel lit up and the dishwasher worked great for 3 weeks, and then it suddenly stopped. No lights or functioning buttons. So I am left wondering if the replacement part failed or if there is another cause. Someone suggested it might be the user interface controll board WD21X31902C, but as everything worked like normal for a while with the part I used, I am hesitant to purchase another $180 part that may have nothing to do with my problem. What can I do test for the problems source?
Since the new machine control made the dishwasher work normally for three weeks, I would not buy the UI board yet. You can narrow this down pretty decisively with a multimeter. This exact model uses about 13.5 VDC from the machine control to power the UI. AppliancePartsPros Forum
Start with the green LED on the machine control
Remove the lower access panel and look at the small green service LED on the control board you replaced. With power on, tell me what it’s doing: completely off, solid green, blinking about once per second, or another blink pattern.
That alone gives us a useful direction. A dead LED can mean loss of incoming power or a failed machine control; a steady LED or communication-type blink pushes us toward the UI or the wiring between the two boards. AppliancePartsPros Forum
Then make this voltage test
Live Power Warning: This next test requires the dishwasher to be powered, so you’re working around 120 VAC.
You should have approximately 13.5 VDC. This is the particularly useful test on the GDT655SMJ2ES. AppliancePartsPros Forum
The results make the diagnosis much easier:
About 13.5 VDC at the UI + UI completely dead: the WD21X31902C UI board is the likely failure.
No 13.5 VDC at the UI: don’t replace the UI yet. Check the door wiring harness and connectors between the machine control and UI.
13.5 VDC leaving the machine control but not reaching the UI: you’ve found a harness/connection problem. A broken communication/power wire in the door harness can produce exactly this symptom. AppliancePartsPros Forum
No 13.5 VDC leaving the machine control: verify the machine control has proper 120 VAC input. If it does, the replacement machine control has likely failed.
I would pay extra attention to that door harness in your situation. A wire can be broken internally and make contact depending on door position. That could also explain why replacing/disturbing the machine control seemingly fixed everything for three weeks. In fact, APP troubleshooting information for this exact model specifically points toward the door harness before the UI when the machine control has already been replaced. AppliancePartsPros Forum
So don’t spend the $180 yet. Check the green LED first and tell me exactly what it’s doing. From that, I can walk you through the next meter check and where to put the probes.
