GE Dishwasher GDF450PGR5WW running with the door open, draining with no water in DW, water not filling
Brand: GE
Model Number:GDF450PGR5WW
Main Symptom: Running with the door open, not filling with water, draining with no water in DW
That indicates an issue with the main control board WD21X32938, probably a stuck relay or logic issue. The service manual for this model states that the drain pump should not run with the door open.
