My GE Dishwasher will fill with water when selecting either wash or rinse setting, but does not send water through the spray arms. The dishwasher remains silent for the normal length of a wash cycle then drains. Any ideas? Thanks!
[QUOTE=wllindsey524;896353]My GE Dishwasher will fill with water when selecting either wash or rinse setting, but does not send water through the spray arms. The dishwasher remains silent for the normal length of a wash cycle then drains. Any ideas? Thanks![/QUOTE]
Willindseay, You’ll want to run the test mode, and see if you’re getting voltage to the wash motor/pump. You may have a faulty relay on the control board [AP4484676] Use the attached tech data sheet to test the control and motor windings on the wash motor
31-30625.pdf (1.0 MB)
