Our GE dishwasher no longer drains completely.
I followed a few of the threads on this site, but I wasn’t able to remove the filter sump and cover assembly -
GE WD22X10077 Filter Sump and Cover Assembly - AppliancePartsPros.com
Someone said it was difficult to remove and they weren’t kidding.
I removed the fine filter and only found a few small items in there.
I used a shop vac to suck up almost all of the water from the sump and reached down into the sump filter but wasn’t able to reach into the hole on the side of it.
We ran the dishwasher on a rinse cycle and it fills up okay but I think when it’s supposed to be draining, nothing happens. If you put your hand on the door, you can feel a slight vibration, as if something is running, but it doesn’t seem to be draining.
Any help or advice would be greatly appreciated.
