GE Cafe French Door CYE22TSHKSS 2 Issues (Ice maker flap not opening & water drip inside freezer)
Brand: GE
Model Number: CYE22TSHKSS
Main Symptom: 2 Issues (Ice maker flap is not opening when trying to dispense ice, but the machine is turning/crushing the ice - might be actuator. Second problem is I see water dripping inside the ice machine from time to time. It creates layer of ice on the bottom of the freezer. If the layer of ice is thick enough, eventually water will leak out)
What happens & when: These problems have been going on for over 1.5 years. I have been getting ice by opening the door, and I crushed and removed the layer of ice every few weeks or so. Would like permanent fix. Thank you
Parts or tests already tried: I have gone to the back of the freezer and clean the drain pipe, but it’s pretty clean and not clogged. I can see the tiny water line inside the freezer on the back.
Hello! Based on what you’re describing with your GE Café refrigerator, model CYE22TSHKSS, I believe you’re dealing with two separate problems. The good news is that both can be diagnosed without immediately replacing expensive parts.
1. Ice dispenser flap won’t open
Since you can hear the auger turning and crushing ice when you press the dispenser paddle, the ice maker and auger motor are at least functioning.
The problem is more likely with the dispenser door actuator, the flap mechanism, or the linkage connecting them.
Here’s what I’d recommend checking:
  1. Remove the ice bin and inspect the ice chute for any ice buildup or broken plastic.
  2. With the ice bin removed, look at the dispenser flap from the outside. Make sure it isn’t frozen shut or physically stuck.
  3. Reinstall the bin, close the refrigerator door, and press the ice dispenser paddle.
  4. Listen for a separate clicking or humming sound from the flap mechanism.
  5. If the auger operates but the flap never moves, the actuator or its linkage becomes a strong suspect.
One important check: If you can gently move the flap by hand and it opens and closes freely, that points more toward the actuator or its electrical supply. If it’s difficult to move, inspect the flap, hinge, and linkage before ordering anything.
2. Water leaking and ice forming on the freezer floor
This problem sounds very much like a freezer defrost drain issue, even though you’ve already cleaned the drain tube from the back.
Here’s why: During the automatic defrost cycle, frost melts off the evaporator coils. That water should flow into a drain trough, down a drain tube, and into the drain pan underneath the refrigerator.
If the drain opening inside the freezer freezes over, water can run onto the freezer floor instead. Over time, it forms a sheet of ice, and eventually water can leak onto your kitchen floor.
Cleaning the drain tube from the back doesn’t necessarily clear an ice blockage at the upper drain opening.
What I’d check next
  1. Unplug the refrigerator.
  2. Remove the freezer drawers and rear interior evaporator cover as needed to access the drain trough.
  3. Look for solid ice in the trough underneath the evaporator.
  4. If you find ice, melt it using warm water and towels. Avoid sharp tools or high heat.
  5. Flush the drain opening with warm water until it flows freely into the drain pan underneath the refrigerator.
  6. Inspect the drain tube and its outlet for restrictions or a rubber fitting that may be sticking closed.
If the drain repeatedly freezes after being completely cleared, we’ll want to investigate why water isn’t draining properly rather than continually removing the ice.
3. One additional test for the water leak
Because you mentioned seeing water dripping inside the ice maker, I’d also check for a leaking ice maker fill tube or water inlet valve.
Try turning the ice maker OFF for 24–48 hours while leaving the refrigerator running normally.
  • If the water stops appearing: Suspect the ice maker fill tube, fill cup, or water inlet valve.
  • If water continues collecting on the freezer floor: The defrost drain becomes the stronger suspect.
The small water line you see at the back may be the ice maker fill line, which is separate from the defrost drain.
A couple of questions
Before recommending replacement parts, I’d like to clarify two things:
  1. When you see water dripping, is it actually coming from the ice maker area in the upper refrigerator compartment, or from the back wall of the bottom freezer?
  2. Is the ice dispenser flap completely closed and refusing to open, or does it stay partially open?
Those two answers will help narrow down the repairs and avoid replacing parts unnecessarily.
Thank you for the Reply.
  1. no ice build up and nothing in a way
  2. I was able to move the flap open and close. All the way open to all the way close with no resistant
  3. I dont really hear the humming from the flap. Maybe the auger is too loud
  4. Auger moved, but flap never moved.
I will take apart the freezer compartment and check the evap (if itz freezing) and the drain hole. Wait, sorry. I actually need help with instructions on how to remove the freezer door and how to take the back cover off. Thank you.
    so I see the water accumulate inside the freezer. I see a frozen water drip mark on the back cover (i’m assuming the interior evap cover) inside the freezer compartment. Sometimes, when i tried to remove the thick layer of ice, I witnessed the water actually drip along the back cover. I think what make the leak is the layer of ice is too thick and can not hold it anymore. Leak thru freezer opening. When i pull the fridge out and inspect the back. It’s completely dry. The back drain hole is clear too.
  2. Is the ice dispenser flap completely closed and refusing to open, or does it stay partially open? Yes completely closed and refuse to open. I can activate the auger and open the flap manually and ice would come out.
Thank you for the detailed update! That really helps narrow down both problems.
Based on what you’ve described, I believe we’re dealing with two separate issues: a possible frozen defrost drain in the bottom freezer and an ice dispenser flap that’s not being activated.
Let’s start with the freezer since that’s where you’re seeing the water and ice buildup.
1. Removing the freezer drawer and rear evaporator cover
On your GE Café CYE22TSHKSS, you shouldn’t need to remove the entire freezer door just to inspect the evaporator and drain. However, removing the drawer front and baskets will give you more working room.
Before starting, unplug the refrigerator.
  1. Open the freezer drawer completely and remove the upper sliding basket.
  2. Remove the lower basket to expose the drawer rails and mounting hardware.
  3. Look along both sides where the freezer drawer front attaches to the slide assemblies. You should find mounting bolts or screws securing the drawer front.
  4. Support the drawer front while removing the mounting hardware. It’s helpful to have someone assist because the drawer front can be heavy.
  5. Carefully lift the drawer front away from the rail assemblies. Take a picture of the mounting arrangement before removing anything so reassembly is easier.
The exact fastener arrangement can vary, so don’t force the drawer front if it doesn’t release easily.
Removing the rear evaporator cover:
  1. With the baskets removed, locate the plastic evaporator cover on the freezer’s rear interior wall.
  2. Remove the screws securing the cover. Check around the perimeter for any additional fasteners.
  3. Carefully pull the cover forward. If it feels stuck, don’t force it. Ice may be holding it against the evaporator.
  4. If there’s a fan wiring connector attached to the cover, disconnect it before removing the cover completely.
  5. You should now be able to inspect the evaporator coils and the drain trough underneath them.
2. Checking the freezer drain
Since you’ve already confirmed the external drain tube is clear, I suspect the blockage may be farther upstream, where the water first enters the drain beneath the evaporator.
Here’s what I’d check:
  • Look for a thick layer of ice in the drain trough beneath the evaporator.
  • Check whether ice is covering the drain opening.
  • If you find ice, melt it using warm water or a hair dryer on low heat, keeping it moving and away from plastic parts and wiring.
  • Once the ice is gone, slowly pour a small amount of warm water into the drain trough.
The water should flow through the drain and into the drain pan underneath the refrigerator.
If the water backs up, there’s still a restriction somewhere in the drain system.
Avoid using sharp objects to break up the ice because the evaporator tubing can be damaged easily.
Also, take a picture of the evaporator before melting any frost. The frost pattern may help us determine whether there’s another problem contributing to the buildup.
3. Ice dispenser flap not opening
Your latest test is especially helpful.
You’ve confirmed that:
  • The flap moves freely by hand.
  • There’s no ice blocking its movement.
  • The auger motor operates when you press the dispenser.
  • Ice dispenses normally if you manually open the flap.
That tells us the ice delivery mechanism is working, but the flap isn’t opening automatically.
My first suspect would be the dispenser door actuator or its mechanical linkage.
The next step is to inspect the dispenser assembly.
  2. Inspect the dispenser trim and control assembly for its retaining clips and fasteners. Avoid prying against the finished door surface.
  3. Once you can access the flap mechanism, look for a disconnected linkage, broken actuator arm, or damaged mounting bracket.
  4. Check that the actuator wiring connector is securely attached.
If everything is mechanically connected, we’ll need to determine whether the actuator receives power when the dispenser is activated. I wouldn’t recommend replacing it until we’ve checked that.
4. A couple of things I’d like you to check
When you get the freezer evaporator cover removed, please let me know:
  1. Is there a solid block of ice underneath the evaporator, especially around the drain opening?
  2. Are the evaporator coils heavily covered in snow or frost, or is the ice mainly collecting at the bottom?
  3. When you manually open the dispenser flap and release it, does it spring closed by itself?
Those answers will help us determine whether the freezer problem is simply a frozen drain or something affecting the defrost system, and whether the dispenser flap mechanism is operating properly.
You’re making good progress, and I think we’re getting much closer to identifying both problems without replacing unnecessary parts.
