Gas Valve Solenoid Coil
How do I know if the Gas Valve Solenoid Coils are bad and are the cause to my dryer not heating. I tested continuity on Ignitor, Fuse, Thermstat, thermocoil, and heat sensor. All show continuity.
Woud i get a continutiy reading if I was to test from one coil to another? I currently do not get a reading and believe this is where my problem is.
Hi Teewaddy
What parts did you call “thermocoil” and “heat sensor”?
The power to the igniter comes through:
[CENTER]The thermal fuse[/CENTER]
[CENTER][/CENTER]
[CENTER]The cycling thermostat[/CENTER]
[CENTER][/CENTER]
[CENTER]The hi limit thermostat[/CENTER]
[CENTER]The flame sensor[/CENTER]
[CENTER][/CENTER]
[CENTER]The holding and the secondary gas valve coils[/CENTER]
[CENTER][/CENTER]
[LEFT]All of these parts should be normally closed. The holding and booster coil (the one with the three terminals) should be checked across outer terminals.[/LEFT]
[LEFT]Good luck.
Gene.[/LEFT]
Per your question below.
"What parts did you call “thermocoil” and “heat sensor”? I checked all of the below that you listed below. All tested normally closed or as I call it “received a beep” from my ohm meter testing for continuity. Is this true?
The Thermal Fuse, The cycling thermostat, The hi limit thermostat, and the flame sensor all beeped/showed continuity.
If I could clarify your next statement “The holding and booster coil (the one with the three terminals) should be checked across outer terminals.” Do you mean that I shoud have continuity from the 3 tab coil over to the 2 tab coil? Because I dont receive a beep from my ohm meter when I check any combination from the three to the two tab coil.
Thanks for clarifying for me.
Both coils should be checked separate, one at a time. The one with the three terminals should be checked across outer terminals.
[QUOTE=Gene;4621]Both coils should be checked separate, one at a time. The one with the three terminals should be checked across outer terminals.
Gene.[/QUOTE]
Gene, how many ohms is too many across the coils, I get about 500 to 1500 ohms with my fluke digital meter?
Hi pmmr
What is wrong with your dryer? What is the complete model number?
Please post it as a new thread.
