Brand:whirlpool
Model Number:wfg550s0hz0
Main Symptom:oven won’t light
What happens & when:won’t light
Error Code (if any):none
Parts or tests already tried: see text below
Problem description:
Gas oven WFG550S0HZ0. Stove top burners work well. But oven burner won’t light. I press bake and set a temperature but oven burner doesn’t light. Do not hear spark and do not smell gas with oven door open. Suspect oven igniter, gas valve, or control board. Also could be spark module if it controls all stove top burner’s spark and oven igniter although it’s description implies ot provides top burners spark only. Can you suggest troubleshooting procedure to isolate faulty part? I would appreciate any advice you have.
Best regards
