I have a gas dryer and it was working fine. We smelled a little gas and had the gas company come by. They had me change the gas hose going from the dryer to the gas pipe with a yellow hose instead of the grey hose that had came with the dryer.
From that point on the dryer will ignite and the flames will come on but then after a little bit the flames shut off and there is no heat in the dryer to dry the clothes
We then have to run about 3 to 4 cycles in order for the clothes to be dry. This is time consuming and costly because of the energy that it is using.
What should I do to get the dryer working?
I have replace the exhaust hose going from the dryer to the ceiling/outside already.
