I have experienced what so many have described before with the dryer cycling once and then the igniter glowing and the gas not igniting. I have replaced the coils but it still does the same thing. Is there anything else that you suggest might be the problem. Could these coils be bad also or is the valves bad. Please help. I found the model number it is LNC8375A80
thanks
