Fuzzzzy
HI!
I have replaced the control board and after I did the washer was working for about a week, then it went back to the sane thing it did. Before I changed the control board the quick wash light came on and the washer did not work if I hit the start butter the cancel butter light comes on and the washer just hums. it hums for about a min. or so. I chang the control board and it work for about a week. now the washer stoped working and when I push the start butter the cancel light comes on and hums gain, after a min. or so the pot and pans light with the high temp light comes on and every thing stops. should I replace the control board again or could it be something else p.s. i have another new control board
          thank you  fuzzzzy
Where is that humming noise coming from? Removal of the bottom panel will help you to pinpoint it. Post the results.
