Frigidaire wont drain, pump replaced - what next?
I bought this dishwasher used as a combo with a stove. It washes, but won’t drain. I read the problems others have posted and am stuck.
When it happened the first time I ran it, I hooked a shop-vac to the end of the drain line next to the disposal, it drained it no problem. I then took out the filter and inspected for blockages, I have not found anything. So I figured the pump wasn’t working, replaced that this morning and when the cycle was complete I still had a tub full of water. I checked the float, not clogged and seems to travel up and down without a problem.
It does make a weird vibrating/humming sound, that I thought was coming from the drain pump, but with the new one in, it did it again, don’t know if that sound is normal or not. Any help is much appreciated!
Moammar Gadhafi’s ground forces capture strategic petroleum city Wednesday and mobile another major attack range, almost offset the eastern city of international air strikes has earnings after rebels began. The rebels, and more requests for help, U.S. officials say government forces are make them more difficult goal of using civilians “battle wagons” with makeshift weapons, not as a tank.Western powers continue to exert pressure to force Gadhafi new air strikes in other parts of Libya, suggesting that they may arm the opposition and intense negotiations behind the scenes to find a country gives Libyan leader haven, and more than 40 years.Also on Wednesday, an American officials and former U.S. intelligence official told ap, the cia agents were sent to Libya in this month, the agency’s station in the capital was forced to close. The cia officials also help save two crew members of a F - 15E strike eagle crashes, they said. They spoke on condition of anonymity because of the sensitivity of the methods of information.===================Google提供的广告================== 网上真人百家乐 网上斗地主 真钱斗地主 澳门百家乐 澳门百家乐================================================
Did you pop out the drain plug on your disposer.
Below is a good install sheet that applies to most dishwashers
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=31-30515.pdf
Yes! That was the problem, thanks fore the help!
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
